Complete ripout
Dave0176
Member Posts: 1,178
Started a complete ripout and replacement of a very inadequate duct system including all 4" branch lines. I recut all the stackheads in and ran new trunk. The old return was tiny at 18X7 which fed a oversized 100,000 BTU Janitrol furnace. Going in with a York 96% 80,000 BTU furnace and a York 17 SEER condenser. It's a lot of work but we're moving along.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
1
Some updates
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Looks good. Scorched air is not so bad if the ductwork is sized right0
Great looking job. Do you make all your own rect duct?
Looking at the large box on the bottom of the RA drop, what do you use for air filter?0 -
Nice job @Dave0176ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
