Purple Primer
GW
Member Posts: 5,184
Don't be this guy!
Hint, you need to "unload" all that purple stuff off of the dauber before you apply to pipe.
Hint two: hold the PVC up in the air so any excess primer doesn't go steaming down the pipe.
Hint three: until you're a purple pro, when you get a new can of purple find a proper place to dispose of half your new can. Now you can more easily whip off the excess primer off your dauber.
Peace
Peace
2
I used painters tape when I did my sump pump pipe. Nice clean line.
I won't bring up the new can of "clear primer" I have sitting by my desk right now though. Also, for inspectors, they make unpurple primer that glows purple when exposed to a UV light.
I mean, neatness still counts of course.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I wonder what the floor looked like??
I should talk, I'm generally good for kicking the can over once in a while0 -
My experience with purple primer is that it does not clean or soften the pipe. I applied it and then the clear cleaner/primer and then the solvent/glue.
A little purple added to the glue gives a nice purple ring at the fitting. I use the clear cleaner/primer and then the glue.
Finally ran out of the purple "primer" so no indicator anymore.0 -
I like seeing purple myself. I think even though the "approved" clear is approved, some old timer plumbing inspectors might start looking for things to pick it if they don't see purple. Just an opinion. Go purple!0
I recently found out there are more PVC primers and cements available than I ever imagined.
http://www.supplyhouse.com/PVC-Primer-1419000
You've got your purple, your un-purple, your clear,.
For cements, different speeds, different bodies etc.
http://www.supplyhouse.com/Plastic-Pipe-Cements-12173000
I think I went with clear primer, and regular build medium set cement.
AFAIK the purple is required around here, so the inspectors can tell "it's been done right".
Ohhhh kayyyy...
I think it was Homer Simpson who said, "mmmm, purple. "
Some township codes by me spec purple.0 -
Yeah, that purple primer works well; too well and if you look away for a second or tip your wrist the wrong direction, it's all over everything. If it gets all over the PVC pipe, your reputation is ruined. No more "Master Plumber".
The trick is to use the clear primer and to do your work without a permit. : )8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I have been through Spears manufacturing training for glueing PVC joints. The primary difference between the "primer" and the "glue" is the glue has filler (pvc) and the primer does not. As they said the primer is really just the glue with no "body". The fillers in the glue are there because the socket is actually a tapered fit and has an interference at the bottom and a clearance at the top. They really emphasized the primer was a critical component in the process. There was much more to the training but that was the basics on the glue/primer.
One final point they made, without primer all warranties are void as they view that as improper installation. Some may not care about that, but the volume of PVC we use this is an important note.0 -
The purple is required by code in my area also.
Purple primer, pipe dope, and anti seiz are the worst for me.0
A few years back here in NH they tried to keep the purple primer clause in the plumbing code for the state.
They got such a back lash from so many licensed guys that they had that sentence removed....
We don't need to worry about that on heating vents as PVC is not allowed here any more.0 -
Guys,
Did you miss the un-purple primer that shows up with a UV light? This should pass code as well, just make sure you have a portable UV light for the inspector and the product to show him what it says.
I don't care who you are, or how careful you are accidents happen, especially when you're trying to get the job done.
When my ex heating contractor was installing the PVC pipe to and from my W-M Ultra-3, they put purple primer on all the joints. This showed the inspectors that it was done right. Ha! They forgot to use the glue on some of the joints. Primer alone does not do the job at all.0 -
Hence the "quotes". If it's important that it's done right, they should have to check for glue, not purple primer. That only proves that it's been primed...Jean-David Beyer said:AFAIK the purple is required around here, so the inspectors can tell "it's been done right".
- 120 Geothermal
