what replaces my TACO circulator pump ?
seandarcy
Member Posts: 21
I have a circulator pump for radiant that I think has gone bad. Sometimes it works, sometimes doesn't. Sometimes it starts, then just stops. But I can't find the same pump, and I'm looking for a replacement. It's a green cylinder, with TACO model number 080-921 ( maybe 7 ? ). I'll try to post a photo.
There are valves above and below the pump, so it seems like a pretty straight forward DIY project. Is it ?
It could also be the thermostat. Is the pump wires to a relay control box? Usually there are indicator lights indicating when there is a cll for heat.
If the call for heat light stays on check voltage at the pump.Bob "hot rod" Rohr
The indicator lights are on at the relay control box. When there is a call for heat, the pump heats up, but the pipes do not get hot. Sometimes, it does work, and the pipes get hot.
I will check the voltage at the pump.
Any suggestions on a replacement ?0 -
The model number will be located on the electrical box. That number is just the sticker number.
But, yes, something's afoot with the circ turning on and off randomly.
Dave HDave Holdorf
Taco, Inc
Yup, on the electrical box. TACO 007-F5-1IFC. I only see 007-F5-7IFC available. Is this just the newer, shinier model, or do I need to find the 1IFC model ?0
You don't need to find the older model, much less will you be able to and it would be way out of warranty. So you can stick to the exact same one or even upgrade to the newer ECM version, 007e. This will fit in the exact same spot as the 007.
Dave HDave Holdorf
Taco, Inc
How does the pressure in the system look? Does it bounce up and then down to a very low pressure?
Rick0 -
Hi - I have a taco 007-F5-1IFC that died a couple of weeks ago. I'm not sure what the difference between the multiple IFC versions is (they all seem to be the same size) but is there something I should be particularly concerned about? Otherwise, can I simply replace it with the 007-F5-7IFC or 007e (which seem to be the most commonly available ones)? Thanks in advance for any help/guidance.Dave H said:You don't need to find the older model, much less will you be able to and it would be way out of warranty. So you can stick to the exact same one or even upgrade to the newer ECM version, 007e. This will fit in the exact same spot as the 007.
Dave H
Saul0 -
It looks like the 007e would be a nice upgrade assuming it is baseboard heat or other low head application.
What type of system are you attaching it to?
@Dave H would be the one to ask."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
007e would be an awesome choice.Steve Minnich0
Thank you both. Yes, baseboard heater. The previous owner built a nice multi-zone system (he probably overdid it but I'm sure there was a good salesperson behind it hehe). This particular zone is connected to a line voltage thermostat in the basement, so, if I go with the 007e, I may swap it with one from a different zone (and use the 007e in a busier zone).
Regarding the old IFC, am I right to assume from your answers that the 007e replaces the IFC without a problem?
Thank you again for your help!0 -
The 007e will replace all 007's. Its not a delta P or T pump. The difference is that it uses a more efficient motor.Steve Minnich0
Saul,
The only thing you need to be concerned with is a 007, the different numbers on the end just mean small manufacturing revisions which usually doesn't mean it translates to the field worth noting.
The 007e is also an IFC circ, except that the IFC is not installed in the circ, it is included in the box so that you can either use it or not.
The 007e is a more efficient circ in power usage and can also change speed automatically if there is a pressure change in the loop. So yes, the 007e is a Delta P circ if there is a pressure change to occur meaning the opening or closing of zone valves. If you are zone pumping, it will be a fixed speed circ but consuming at least half the power of the 007 if not more depending upon the size of the zone (where the system curve meets the circ curve) it could use even less power!
So, it your choice, 007e or the 007-XXXXXX
EnjoyDave Holdorf
Taco, Inc
-1 -
That's Ok @Stephen Minnich
That's the beauty of it, the simplicity if you want, the variable speed if you want. No dials, buttons or programming.
Dave H.Dave Holdorf
Taco, Inc
@Dave H - I read all the sales sheets on it before and after your post just to confirm I didn't miss something. Is there a reason its not necessarily advertised as delta P?Steve Minnich0
You're right @Stephen Minnich . I just re-read everything myself on the website. We don't flat out state that it is a Delta P or variable for that matter in so many words.
What I do find is the constant pressure curve shown multiple times for 10' of head where it will vary its speed. So I will make a note of it and get it back to the powers-that-be.
You know when you are close to a project and understand it it inside and out, sometime the obvious is forgotten when writing it down for the masses.
Thanks and Enjoy
Dave H.Dave Holdorf
Taco, Inc
Thanks @Dave H - I saw the curve too. Love the new pumps you guys are coming out with.Steve Minnich0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
