Which PEX for main supply Water?
LionA29
Member Posts: 255
I'm looking for recommendation on which PEX to use to run my main supply house water through the basement wall,ceiling and may be close to my main steam 2" run. Which company makes it and I would think " blue/white" color? Not too familiar with PEX, any input will be gladly appreciated!
Thanks
Thanks
I like Pex-a products like Uphoner Aquapex or Rahua with quality expanding fittings like propex . Other guys use crimp fittings Pex-a with good success.
The big box stores carry pex-b and off brand fittings which in my mind is slightly inferior.
Don't get any plastic pipe near a steam pipe. It could melt the pipe or make your cold water hot.
Most are available in Red Blue or White for those that are easily confused."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
How is PEX B? Is it more rigid and heat tolerant?0
I prefer Pex-a. It is a predictable product to work with and has a great track record.LionA29 said:How is PEX B? Is it more rigid and heat tolerant?
It does look like Pex-b is a bit stiffer and theoretically more heat tolerant. http://www.pexheat.com/Home/5-Lies-About-PEX-Tubing
Do not put any pex piping in close proximity to steam mains..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
