boiler(oil)
bone38
Member Posts: 1
in Oil Heating
Have a utica boiler(OIL) about 2-3years old .Water is extremely hot and very concerned with young children in the house. Should a temp valve been installed during installation? There is currently no way to adjust water temp.
Thank you
Thank you
I take it this is the domestic hot water? And is this a hot water heat system?
How does the domestic hot water get heated? Is it a separate loop (I hope) to a storage tank?
I ask these questions because if it is a separate loop with it's own controls heating a storage tank, there should be a thermostat -- called an aquastat -- for that storage tank which controls the temperature in the tank. That may have failed, or it may be set incorrectly.
In any event, the system which I would prefer would be that the domestic hot water supply come through a mixing valve, which should be adjusted so that the temperature of the hot water supplied to the house is not over 120 F -- and could be less, if preferred.Br. Jamie, osb
If it's a tankless coil it should have been installed with a mixing valve. Need pictures0
- 120 Geothermal
