adding wall control to control heat and a/c for high rise condo unit with convectors
rosn
rosn Member Posts: 1
We own a one bedroom condo unit on the 39th floor of a high rise. Each unit has convector units that control the heat and air conditioning. If we want to add wall controls to control the heat and a/c, what type of contractor do I contact.? I believe the overall heat and a/c is controlled by a boiler system.
  • Ironman
    Ironman Member Posts: 7,873
    An HVAC/Mechanical contractor that knows commercial controls.
    Bob Boan
  • While you are looking for the right contractor, can you tell us about the problems you now have with the system? Are you too hot in winter, or too cold in summer?
    I suspect that this is a symptom of a system wide problem, and that all work on the system should be done by the condo regime, as it is a common element, like the roof. If botched work is ever performed on one unit, it can have a negative effect for everyone.--NBC
