Replacement for the LightRay Furnace
Ironman
Member Posts: 7,735
This is where we started (as previously posted in another thread):
And this is where we are now:
Along the way:
This system was a combination of a 120+ year old one and two pipe air vent system. One of the returns would not hold air pressure and was inaccessible; so, we did a modification and eliminated that return and one first floor rad and re-worked the branch feeding the other rad's to drain counter Flow:
Two Big Mouth vents clear the 80' 2 1/2" main in less than three minutes.
Along the way:
Bob Boan
1
So this is the exact same boiler as the lennox GSB?
And it worked well with the 2 2inch risers?0 -
225,000 BTUH input with 7 sections?
And a 3" header?0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
