General Zone valve's
andrewgarciasr
Member Posts: 2
in Gas Heating
Please be advised that I am trying to locate two General Zon-Val, Zone Valve Power heads.
Please review and please advise if you have any available for sale or do you know where to purchase?
Thank you.
Andy Garcia
Thank you.
Andy Garcia
I think General Zone Valves have been out of business for some time. Is this the system with DC voltage to the Zone Valves?0
Yes..24 Volt transformer to the zone valve power head. The piston in the power head is leaking and no longer working to actuate the valve. Please advise if you know where I could purchase a replacement for these power heads or the piston in the power head. Thank you.0
None that I know of. You need to replace the zone valves with some other brand like Taco, Honeywell etc0
I agree, replace the entire valve, they have a life expectancy.
Caleffi has a press style valve, very easy to retro-fit.Bob "hot rod" Rohr
Living the hydronic dream0
- 123 Chimneys & Flues
