General Zone valve's
Please be advised that I am trying to locate two General Zon-Val, Zone Valve Power heads.
Please review and please advise if you have any available for sale or do you know where to purchase?
Thank you.
Andy Garcia
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    I think General Zone Valves have been out of business for some time. Is this the system with DC voltage to the Zone Valves?
  • andrewgarciasr
    andrewgarciasr Member Posts: 2
    Yes..24 Volt transformer to the zone valve power head. The piston in the power head is leaking and no longer working to actuate the valve. Please advise if you know where I could purchase a replacement for these power heads or the piston in the power head. Thank you.
  • Tim McElwain
    None that I know of. You need to replace the zone valves with some other brand like Taco, Honeywell etc
    hot_rod Member Posts: 27,340
    I agree, replace the entire valve, they have a life expectancy.
    Caleffi has a press style valve, very easy to retro-fit.
