Heat Timer Model EPU Blue Control Box
bxre.com
Member Posts: 7
Hope all is well. My issue with this heat timer is the program clock dial is not operating or moving, preventing wand from clicking day into night mode therefore boiler giving heat 24/7...........
Thank You
Thank You
Did you check power to the motor? If you find and post a wiring diagram someone could walk you through it. There may be one on the back of the cover."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
If you have power to the timer motor, then motor is dead. Haven't touched one of these in a while, but I believe it's a replaceable part, similar to the motor on an intermatic timer.0
Thank you ZMAN & Abacadabra:
Had to replace the clock motor on the back of the panel which is identical to the part which motors the intermatic timer.
Part: Heat Timer Corp. 40000304 CLOCK MOTOR 24V 1RPH EPU,EPUCH
None of the plumbing or heating supplies stock this clock motor and Heat Timer does not sell it. Cannot even find it or purchase it online or Ebay, that's how rare this dinosaur part is.
Heat Timer requires to get a 3rd party to yank out the panel and sent it to there HQ in jersey for them to "service it" and after easily over a $1000 and weeks later you know the rest.
Luckily thanks to this website, I was able to find someone who did have the part and swapped it for me in 5 minutes and saved me a massive amount of $. You guys are the best! Thank You!0 -
Im in need of tge same part. The motor ti the timer is humming like a bee and doesnt seem to be moving the dial. Who can i contact for tge part or repair?0
The age of that unit looks like it may have soldered connections. We use to repair them on a regular basis, maybe once a year. Before putting it back in service, might want to check all the connections.0
I have a similar unit in Westchester County New York and would really appreciate someone who can troubleshoot and service the unit. The issue I'm having is that the unit stays on continuously. Can someone please email or text me a contact? My email is FrancoM@miliomanagement.com telephone is 914-403-7623. Thanks!0
Wow guess every boiler room in NYC must have a heat timer0
Hello, Was anyone able to get the Staten Island store info? My heat-timer(EPU) keeps jumpin(turning off) when its on automatic. It try’s to call for heat and clicks 2 times and then stops trying. I calibrated it and then it worked for a month and now it’s jumping again. I changed the relays and it worked for 1 cycle. Also oddly only works from 6am to 7am. Please text me info 347-231-2862.
I have contacted Heat timer directly. They service their equipment themselves in manhattan. I don't see why they would not go to staten Island . They just installed a new Platinum system with wireless sensors and internet controls in one of the buildings I represent. I have been very happy with it.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
