Buderus & Dianorm radiators
I'm considering both these radiators and am having trouble telling if there is any difference at all in their build quality, but I don't have them right in front of me for comparison. They appear to be identical- same integrated valve, same attachments, same appearance, same nomenclature (Type 22, type 33, etc.)
Has anyone worked with these and can tell me if there is a quality difference, or is this an example of two different manufacturers ordering their parts from a single supplier and price should be my only consideration?
  • GW
    GW Member Posts: 5,184
    I've worked with the Buderus rads a bit but more so the Hydronic Alternatives rads. In my most humble of opinions I suspect they're all the same.
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • Zman
    Zman Member Posts: 7,609
    I also have worked with both and believe they come out of the same factory.
    I have had customers that feel they project from the wall too far.
    The runtal panel radiators are more streamline and the actually hang of the wall.
    Albert Einstein
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Both Buderus and Dianorm are very similar. They each use a different style TRV head. At last count, there were more than a dozen companies producing the pressed steel radiators in Europe. At least 3 are imported into N. America.
  • kcopp
    kcopp Member Posts: 4,680
    edited February 2017
    I also have used 3 different Panels rads. I have Buderus in my home. I currently use Biasi and Hydronic alternatives. Quality is all about the same. Biasi is pricewise a better value. The Hydronic alternatives versions have a greater selection in size and shape.
    33 series is going to be hard to get in Buderus... long wait from Germany.
  • roundrightfarm
    roundrightfarm Member Posts: 54
    I had thought the Hydronic Alternatives rads were Buderus. Am I wrong about that?
  • kcopp
    Not the same... although similar.
