Domestic water with an odor.
The house is a relatively new building, 2003 or so. I visited and indeed could smell the water. To me it has a metallic smell maybe coppery. So I flushed the tank, It was full of crud, and replaced the anode, it was 99% gone. Well the odor persists. This building is on city water. I had an independent water tester come and do an on sight test as well as a collection for the lab. The results have not come back yet. But my question for now is; is there some thing I should be looking for in the results? Is there something in particular I should be asking for in the testing?
Thanks for any in sight you guys might have.
Lots of possible causes. But chemicals I'd be looking for would various sulphides -- particularly hydrogen sulphide. That's usually described as rotten eggs, but can be other odours. Also some manganese compounds, particularly with sulphur.
I'd try really really cleaning that hot water tank!Br. Jamie, osb
Larry offers some good tips at his site, buy his book if you are in, or into hot water.
http://www.waterheaterrescue.com/Troubleshooting/stinky-water-in-hot-water-heaters.htmlBob "hot rod" Rohr
Thanks guys. The guy who came out to take test samples did do a test for sulfides on sight and came up with negative. I'll look into that book it sounds interesting.
Wow I just linked to that sight.hot rod said:Larry offers some good tips at his site, buy his book if you are in, or into hot water.
I'll be visiting that place again. ThanksMiss Hall's School service mechanic, greenhouse manager, teacher, dog walker and designated driver
Hello and thanks! I try to help out at Water Heater Rescue as I can... To the question, you might look at the pH of the water, to see if it's attacking the copper pipe and also look for any dead legs in the plumbing. They wind up being great places for nasties to accumulate and grow.
Yours, Larry0 -
Re: Nasties
What temperature is the water heater set to?0 -
The water is approximately 120 though I haven't put a thermometer to it. The initial on sight test shows no sulfur. I assume that is the most common odor complaint?Paul48 said:Re: Nasties
To me the smell has a coppery quality to it which leaks me to believe there is something attacking the pipes.Larry Weingarten said:Hello and thanks! I try to help out at Water Heater Rescue as I can... To the question, you might look at the pH of the water, to see if it's attacking the copper pipe and also look for any dead legs in the plumbing. They wind up being great places for nasties to accumulate and grow.
Yours, Larry
I replaced the water heater yesterday because of its age and the condition of the original anode. Also because this is the Head of Schools residence and we try to keep everything perfect there. I'm sure we will be installing some water treatment in the near future as soon as we get the lab test results back.
I'll keep you all posted. Again, thanks for all of your input.
MMiss Hall's School service mechanic, greenhouse manager, teacher, dog walker and designated driver
- 123 Chimneys & Flues
