Valve Leak Help needed
Hi -
I'm attaching a photo of my low water cut off drain valve, which has been steadily leaking... I don't know whether this can be taken apart and fixed or not, and was wondering if anyone could lend some help.
Thank you!
Thank you!
Is it not closing completely?
Is it marked for its size?
Sometimes, the valve can be opened and closed in quick succession, to wash any rust particles out.
If that does not work, teplacing it would be the easiest course of action, although, the boiler will have to be drained.--NBC0 -
It's a gate valve. Unless it is an older quality valve, they will leak. You can either put a plug in it, or replace it with a ball valve.
Rick0 -
It doesn't close enough to stop the dripping, so I'm guessing there's a gasket or something inside which is failing.
If I go to replace it, I'm not sure how I'd get it off. It's so long, that twisting it would hit the furnace. Can this be disassembled?
And it looks like it has pipe dope on the threads - WD40?
The other side of it says 3/4, and there's an H.0 -
what @neilc said is the way to go. Put a ball valve and a nipple on it and keep the gate valve open for now.
After the heating season remove the old valve. Cut through the valve stem and bonnet so you can unscrew the old valve if you cant get it apart0 -
Just add a 1" or 2" nipple on the end of that valve and use a hose cap on it, until the heating season is over.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
