Slant/fin model em-10 electric boiler control. Alarm goes off
ralph1956
Member Posts: 1
I have one and when it starts to go up to stage 4 an alarm goes off and shuts down. I'm sure it's either an electrical issue or bad relay. Where would I start.
The EM-10 is an OEM control we source from Tekmar. I have a call into our Tekmar representative on this. Normally the alarm will go off if there is a sensor issue. However, I think you may be hearing noise coming from a reply. I suggest you contact Slant/Fin Technical Services about this. Below is the USA and Canadian phone numbers, please call the appropriate number for your location.
USA - 516 484 2610
Canada - 905 677 8400
Thank you,
Keith Muhlmeister
Slant/Fin Corporation
You're slipping, Keith...that came through yesterday...
Yup, what can I say?0
- 52 Job Opportunities
