Water softener and steam boiler
But before I make a decision, I would like to get some Pros and other HO input on this. I've been reading that soften water is bad for the boiler causing it to rust.
So, do I run a dedicated fresh water line bypassing the softener to the steam boiler and outdoor faucet?
By doing that, my boiler fill will no longer be " hot".
Thanks in advance!
Lionel
Actually, depending on the temperature I believe most if not all auto-fills say to never use hot water as it can damage them.Jamie Hall said:Having the boiler feed 'hot" is irrelevant -- you shouldn't be adding more than two or three gallons per month anyway.
Technically.
They do. And when I called McD-Miller, two different tech guys said they have no idea why the paperwork says that and that "surely, it makes sense to fill the boiler with hot water rather than cold water."ChrisJ said:
Technically.
How about that?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
I thought it was because either the seals, or the solenoid were sensitive to it?JohnNY said:
Technically.
How about that?
I swear I read that somewhere or someone told me it.
@Jamie Hall I thought should the boiler needs water if hot, by adding cold water will shock the cast iron and probably cause it to crack?
@ChrisJ I do not have an auto feed and it really don't use any water. So no water is usually added except with I drained the bottom legs.0 -
http://www.wawnc.org/cm/downloads/WAWNC_AWQR_2015.pdf
I found the Water report.0 -
Thermal shock might be a problem -- would be -- if you added a whole lot of water all at once. A gallon now and then? No problem. To make doubly sure though, the water should be added to the wet return, not directly to the boiler.Br. Jamie, osb
@Larry, what's your take on @LionA29 's water report. Chlorides look high to me. Anything else he should be concerned about as it relates to his steam boiler?
-1 -
No problem. BTW, doesn't your supply water go into the boiler down at the wet return before the Hartford loop? Does it actually go directly into the boiler? Typically the fresh water is added somewhere in the wet return just before the boiler so that it is tempered before going into the boiler. Hot water is Ok but if it actually goes into the wet return, cold water will be tempered and fine going into a hot boiler.0
I can't say I've every heard of someone saying to use hard water in a boiler... At work, our makeup FW for our 500HP plant comes through our softeners.0
So I've manage to do some testing of the Supply Water entering the boiler and Water inside the boiler for Hardness.
Supply Water - 8 Grains
Boiler water - 2 Grains
Pics attached.
Thanks0 -
@LionA29 , that now leads to the next question. Have most of the minerals in the water, from 8 grains down to 2 grains attached themselves to the walls/floor of the boiler as scale? I'm not sure about the chemistry between hard and soft water and what the Pros and Cons of each might be but I suspect the suspended solids attach to the interior of the boiler. They don't disappear.0
@ Fred: the minerals most likely have been removed by the softener. My guess!
@LionA29: I take care of a steam boiler in a 12 plex. Owner wanted to know if we should be doing any type of treatment for the boiler water. I had my chemical guy stop by and he said that the best thing we could do for that small boiler (750,000 BTUH) was use softened water for the makeup. We installed a softener just for the boiler.1 -
@Rich_L " He doesn't have a water softener yet.Rich_L said:@ Fred: the minerals most likely have been removed by the softener. My guess!
@LionA29 I don't think you can boil the minerals out. They are typically left behind as deposits, like you see around a pan of water when you boil it.3 -
While you would not want to fill or maintain any hydronic or steam system with hard water, softened water also has some drawbacks. Mainly you raise the conductivity of the water through the ion exchange
The best treatment for water that does not meet the boilers requirement is to demineralization the water. Similar to softening but no brine involved. Some good basics on water for Hydronics here
Search Idronics 18Bob "hot rod" Rohr
Living the hydronic dream1 -
This in what I got out of an electric process boiler fed with unconditioned municipal water. 12 grains hardness, calcium carbonate, I was told this boiler was cleaned weekly with "something". Got 10lbs of this stuff out all below the wayer line.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
WOW!0
@Solid_Fuel_Man ...What in the world is that?
It really looks like Fudge0 -
@LionA29 if I were you, I'd call Rhomar and talk to them about using a softener with the boiler and it's effects.
Also, discuss some water treatment with them while you're at it.
IMO, they're some of the best when it comes to this.
http://www.rhomarwater.com/products/catalog/product-type/steam-treatment/Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
-1 -
The key is to protect all the metals in a steam or hydronic system. Getting a film or coating on them is important.
With O2 in the fill water you will get some oxidization to "rust" the ferrous surfaces. Until the O2 is consumed in that process.
Additionally treatment chemicals add film providers..
Steam guys prefer a bit more alkalinity to protect the iron.
The goal is to keep that water quality in the best range.
Excessive fill water or excessive O2 ingress need to be monitored and addressed, as it will increase corrosion, and scaling potential.
So my suggestion is to test your fill water, fix it if it is out of the boiler manufacturers spec, maintain and check fluid quality occasionally to know if fill water or excessive O2 is entering.
Living the hydronic dream-1 -
I believe @LionA29 spoke with WM tech support this morning and they told him "No" to using softened water in their boilers. I have since spoken to Burnham Tech support and they told me that they want a fresh water line run to their boilers that bypasses the water softener. No softened water.-1
I called Weil McLain and I got " you don't want to feed a boiler softened water".0
@Fred @ChrisJ
I spoke also to Rhomar's chemist Jeffrey and he was very patient. He said the boiler's manufacturers do recommend around 8 grains and that's normal but with the issues I'm having with the scaling it can become a problem later on. Also recommended using Deionized water.
He suggested using Rust inhibitor.So i ask how to treat the hardwater for the boiler? There is a Boiler Pro 903 and Hydro Steam 9510 that should clean the scales out before using the Boiler Pro.
Boiler Pro can be used as a maintenance additive.1 -
True!LionA29 said:I called Weil McLain and I got " you don't want to feed a boiler softened water".
Deionized or demineralized water is what you want, this graphic shows the difference between softened and demineralized water.
RomanGK_26986764589 said:
Or one could use reverse osmosis (RO) water to feed the boiler if possible.
RO would be similar to demineralized but slow and wasteful to produce. 2-3 gallons down the drain to produce 1 gallon of RO water.
Demineralizing cleans all the water flowing through it and at a reasonable flow rate.Bob "hot rod" Rohr
Living the hydronic dream2 -
https://heatinghelp.com/blog/nature-of-the-new-steam-beast/
When testing makeup water, the following are a good rule of thumb:
Chlorides should be less than 30 mg/L (ppm)
Hardness (as CaCo3) should be less than 100 mg/L (ppm)
pH should be between 9.0 and 12.00 -
@LionA29 I checked my area water report and they don't even list chlorides there.0
@RomanGK_26986764589 where are you located?0
@LionA29 I live in NJ. According to American Water, my water is coming from the Raritan system. Here's the link, maybe I am simply not seeing it and you have better eyes. My zip is 08812.
https://amwater.com/njaw/water-quality/water-quality-reports#zip=08812&distance=5&latitude=40.597309&longitude=-74.478818¤tpage=10
- 110 Chimneys & Flues
- 980 Plumbing
- 387 Solar
- 17 Recall Announcements
