Thermostat for steam heat
What thermostat is best for steam heat?
Do not need programable.
Right now I am using a Honeywell round (24 volt) . Switch on back is set for steam.
Have 100 year old system. Historic house in Kingston NY
20 cast iron radiators - one pipe system
Installed used Burnham steam boiler 142,000 btu
DC
  • JohnNY
    JohnNY Member Posts: 3,231
    You are currently using (arguably) the best thermostat for steam heat.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • PinkTavo
    PinkTavo Member Posts: 64
    edited February 2017
    I had the old Honeywell Round (with the Mercury switch) that was likely 40-50 years old and when it went bad I changed to the Round with the digital display. I didn't notice any difference in operation with my steam system. I did have the first digital one fail in the 1st year, but replaced it and the second one has been going for over 10 years. If electronics are going to fail...usually it is in the first 3-6 months.
    http://www.supplyhouse.com/Honeywell-T8775A1009-1-Heat-Stage-Digital-Round-Thermostat-Premier-White-4091000-p
    Jamie Hall Member Posts: 23,366
    Two of the three thermostats in the main place I care for are mercury round Honeywell T87s. There is a programmable digital... why the old mercury ones? Backup. They just don't quit. The only reason for the digital is I wanted to have the setback recovery (3 degrees) before I got going in the morning!
    Canucker
  • LionA29
    LionA29 Member Posts: 255
    @Jamie Hall
    Did it really made a difference with the 3° setback?
    Thanks
    LionA29 said:
    @Jamie Hall
    Thanks
    Not really... not that I can measure. But it's nice to have all the radiators toasty at oh dark hundred on a winter's morning.
    KC_JonesLionA29RomanGK_26986764589Canucker
