Ignition Control for Weil Mclain: M# EG1PEG-35, Series 4
Thanks, Gary
Honeywell S8620C1003
(edit) I see it's discontinued. According to the S8610U3009 it'll replace it with sw1 off and sw2 on
Sorry.. jumped the gun... I just noticed you said Series 4.0 -
What is the part number on the one that is on the boiler now? That way I can cross reference it.0
I think mine is a series 4?
It's from 2011.
I'm not sure if this is the exact number, but it's a United Technologies for sure and this claims it's for an EG series.
http://www.simplyplumbing.com/100674-sensing-control-module.html?gclid=CMWZsqvs6tECFRUKKgodMCIBJw
Thank you guys the part came in and we got it all set. Ill see if my guy has the old part Tim, I'll post it
Thanks, Gary0 -
@ChrisJ , iirc, that's the ignition control in the series 5. The series 4 used a Weil Mclain 1135-605 which was discontinued.ChrisJ said:I think mine is a series 4?
It's from 2011.
Looks like supplyhouse carries the direct replacement:
http://www.supplyhouse.com/Weil-Mclain-381-330-024-Control-Module-UT-11365-605-LWCO0 -
Boiler controls are much less likely to have Universal replacements. Furnaces are much more likely.0
Thanks for the help everyone, my guy chucked the old control into our dumpster, I just took a look and see (jumped right in!) and I can't find it. If this is indeed some Weil McClain only part, I'm not so interested in stocking the thing. I can see 90 plus boilers having their own propitiatory stuff, but for a dumb chim venter it seems nutty!0
I doubt it is.GW said:Thanks for the help everyone, my guy chucked the old control into our dumpster, I just took a look and see (jumped right in!) and I can't find it. If this is indeed some Weil McClain only part, I'm not so interested in stocking the thing. I can see 90 plus boilers having their own propitiatory stuff, but for a dumb chim venter it seems nutty!
At least on mine it's a UT part with a WM part number.
What I got from the manual was before UT, they were using Honeywell.
1
- 116 Geothermal
- 15.8K Strictly Steam
