Laser level
Tinman
Member Posts: 2,808
Can anyone recommend a laser level that they've used and liked? It's not for piping. I'll be using it to drop a ceiling at my oldest daughter's house. I'm removing the collar ties and replacing them with ceiling joists. Thanks.
Steve Minnich
I used one of these for re-pitching a condensate line, worked pretty good. It's big brother comes in a kit with a grid clamp IIRC.-1
I bought this one about 5 years ago. DeWalt DW088K http://amzn.to/2jbFz5x (Mine is actually a DW087K) Paid around $125 back then, and that's why I got it as it was one of the least expensive but decent level available. Actually turned out to be a great buy; have been using it exclusively since then. It's well built, accurate, and easy to use.-1
Go green! I'm waiting for the pice to drop on Dewalt DW089LG. It seems to be one of the top green lasers.Bob "hot rod" Rohr
Yes green is pricey, but less frustrating in brighter lighting.0
I've only used red lasers, but I have had a PLS2 for probably 10 years. It does a single level line, a single plumb line or crossed vert & plumb. I don't use it daily, but it has been through a lot and held up well.0
I'll second the PLS2 they are good.
I have a Johnson laser now it's red projects a dot or vertical and/or horizontal line, self leveling works good. Still finding more uses for it
Gives me the ability to measure up piping jobs by myself.
And you don't have to wait for the plumb bob to stop bouncing!!!!!
Cheapest on I found was clear plastic tube and filled with water. Lol
https://www.amazon.com/Bosch-GLL-2-20-360-Degree-Self-Leveling/dp/B00SWIH9N8
Bosch GLL 2-20 360-Degree Self-Leveling Line and Cross LaserSingle pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
No, but does vertical also. 360 not a must.0
360 is a huge bonus when you're doing ceilings.Gordy said:No, but does vertical also. 360 not a must.
YUGE!Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Not really. Gotta think about the tool, and how to use it. Ceilings may be a one time gig for Stephen.
Now if we are out in the field shooting grades yes.0 -
Yes,Stephen Minnich said:@ChrisJ - Did you just say "Yuge"?
I used it as sarcasm.
Similar to when I use "Cash me ousside" now.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
Stephan Minnich. When I said it would go around corners, I meant the water level JA mentioned.
Rick0 -
Actually a water level is more accurate, and at far greater distances. I enjoy using old school. If you have the time.0
Yes.
That's exactly what @Stephen Minnich is looking for. He wants to carry a huge spool of tubing and a bunch of bottles of water around.
We can tell by the title of this thread. You know, where it says "LaserWater Level" ?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
getting the bubbles out is a problem0
Alcohol. Whiskey for when the job is done. Easy to see.......before the job is done.0
They used to call levels Whiskey sticks. So I've been told.Gordy said:Alcohol. Whiskey for when the job is done. Easy to see.......before the job is done.
Very true.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
