Nest Learning Thermostat compatibility with Oil fired boiler
hjohnson27
Member Posts: 3
in Oil Heating
I bought a Nest Learning Thermostat model T3007ES but when I contacted customer support they said it wasn't compatible with the two wire configuration of my current thermostat. I have radiator heat and a Burnham RSA series oil fired boiler. I have been reading online that I might be able to run new wires so that the Nest will be compatible. I just need advice... is it not compatible because I don't have a common wire? Or is it a voltage issue?
Adding pics for further detail...0
It's mostly the lack of the common wire. Those things eat power -- you should check that the transformer you have can power it OK. If it can, you can run the third wire. There are also some widgets available which are alleged to supply the third wire using the existing two wires; I've not had any experience with them.
You don't say whether you have steam or hot water heat. There seems to be some variance of opinion, but in general Nests -- and other learning thermostats which set the temperature back when the spaces are unoccupied -- don't play well with steam, as steam doesn't like setbacks. They play a little better with hot water -- but there are better ways to control hot water heat which really do save fuel. Nests and their kin are really intended for forced hot air.Br. Jamie, osb
I'm embarrassed to say I'm not sure? I assumed hot water radiator heat? I don't think it's steam. If you bleed radiators that is hot water right?0 -
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
