Change out
Dan Foley
Dan Foley Member Posts: 1,268
This was a hot water change-out Poppy, Lamin and Nelvis knocked out today. It was a no heat replacement in Annandale, VA.
Before pics
  • Dan Foley
    We went back with a Crown cast iron atmospheric. I love this boiler. It's built like a tank.
    IronmanSteve Minnich
  • Dan Foley
    Before pics did not post.
  • delta T
    delta T Member Posts: 884
    I love getting on the wall and seeing other installs where it is self evident that the installer actually CARES!!! Looks great Dan (as always), if only everyone did work like this!
    I was daydreaming the other day thinking about how much money and effort would ultimately be saved if all installs were like this. How many times have you had to fight air in a system for an hour after a routine repair because there is not a purge valve installed? How many hours have you wasted in your life trying to change a pump that was needlessly installed in an inaccessible location? I could go on and on obviously, but I think we have all been there in the dark mechanical room Friday night at 7:30 cursing the person whose ignorance and lack of care put you in that situation. If only, if only....
    Sorry for the rant, its been one of those weeks :s
    Dan FoleyCanucker
  • EzzyT
    EzzyT Member Posts: 1,377
    Beautiful install as always Dan.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Dan Foley
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Nobody does it better...good work!
    Dan Foley
  • Henry
    Henry Member Posts: 998
    Is this a clay lined chimney? The piping is very nice
    Dan Foley
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    Well done, Dan, Poppy, Lamin, and Nelvis!
    President
    HeatingHelp.com
  • Dan Foley
    Thanks, All. Poppy and crew get the credit for this one-day replacement.
    @ Henry
    The chimney is an interior clay lined masonry chimney. The boiler is common-vented with the existing gas water heater.
