Smelling fumes after heater is on for a while
Leela
Member Posts: 4
in Oil Heating
I have a 3 year old Williams wall heater with smell. I called the gas company, they came out, tightened the gas line. It was still happening, I called them again, and they say no gas leak. After I turn the heater on for a while (1/2 hour or so), I can smell exhaust like fumes concentrated around the kitchen and bathroom in an 1 bedroom apartment, usually at night or early morning about half an hour after the heater goes on. Good thing that I don't need the heat that much in Southern CA, it's still annoying. There was no smell last couple of years, just started smelling about a month ago. Building maintenance was clueless. Any suggestions would be appreciated. Thanks.
It could be a crack in the heat exchanger. If this vents the exhaust through the wall make sure the exhaust port it clear and that nothing is pushed up against it.
3PSI gauge0 -
Forced air heaters/furnaces sometimes have a peculiar smell when they are turned on for the first time during a heating season. Kind of like an iron when pressing a garment but it goes away after the first cycle, maybe two. Is that what it smells like? Do you have a CO detector? It may be a smart idea to have one somewhere near that area.0
Smell like car exhaust. It has been a month since I started noticing it. I have a couple of CO detectors next to it. Right now I just air it out a bit but that's not a solution.0
That's not right. How is that heater vented to the outside? Did the gas company check the flue pipe to make sure it isn't clogged with a nest or that it hasn't come loose? A picture of the unit would be very helpful.Leela said:Smell like car exhaust. It has been a month since I started noticing it. I have a couple of CO detectors next to it. Right now I just air it out a bit but that's not a solution.
How old are your CO detectors...the do have expiration dates. Also, most off the shelf ones will not alarm at low levels. I would have a competent HVAC tech come out and check to see if there is a crack in the Heat exchanger. Car exhaust is not the best smell to be coming from a furnace. If it were mine, I would turn it off until you have it checked, it could be dangerous. Any one in the house get any flue like symptoms since you noticed the smell?0
Contact the owner/property manager and inform them that the unit needs professional attention. Ask them how they would like to handle the situation.0
I'll relate that to the maintenance person. They had called in a "professional" person, he didn't detect the gas leak. SDGE detected the gas leak. So, I'll see if they can get a competent professional.0
Tell them, for safety reasons, you'll need a copy of the digital combustion analysis. @Tim McElwain
Maybe Tim will weigh in on this. He runs a gas training institute.1 -
No exhaust fan running. Exhaust fan in bathroom only, kitchen fan is for circulation only. Kitchen has 3 walls, think that's why smell accummulates there. I usually just open the window. 50 degrees it's manageable.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
