Oil transfer pump
bob eck
Member Posts: 930
Looking for a oil transfer pump for pumping out oil tanks.
What brand / model
What brand / model
I've had Hamco's rubber impeller pump for yrs. 3/4 hp. Like a pony pump on steroids. Unbelievably fast, not cheap tho. Stock an extra impeller, they do swell and stick if the pump sits a long time.0
How much transferring, how often used?
I've been using the cheapo plug in water pump, male hose fittings on either end. I made up a steel dip tube and use dip tube>washer machine hose> pump> hose to holding tank-about 15gpm.
This last one I've had about 10 years. The one before went about the same. When it starts to leak/fail, just toss it and buy another.
Now if you're pumping all day/every day, then I'd bump up to what Bob mentioned.There was an error rendering this rich post.
Used to use vacuum tank.0
This is what we use. 13GPM. Relatively quiet. Works fine for the 4 or 5 tanks we do a year.
http://www.fillrite.com/index.cfm/products/productdetail/?p=276&ps=1150 -
- 62 Biomass
