Do you use CFD software to ensure air quality?
andreea
Member Posts: 4
I found these free webinar recordings that teach you how to perform CFD and thermal analysis for HVAC systems simulation, including air quality and contamination control applications. They are really interesting, but I was wondering if the majority of HVAC engineers are using simulation in the design phase (of rooms, buildings, garages, cleanrooms). Or do you mostly rely on manual calculations?
-4
The software you mention didn't exist 9 years ago, when I retired. There was a mishmash of regulations and guidelines, and it was further divided on whether you were designing commercial or residential systems. In commercial, you had EPA, OSHA, ASHRAE and special state requirements that were followed for schools. Hospitals had their own set of regulations. In general, most had to do with ventilation; air changes per hour, the level of chemicals that were allowable and particulate levels. OSHA regulations had nothing to do with comfort; they were mostly for the factory floor, and were set so the employee exposed would not be injured. Typical gases and vapors monitored were CO, CO2, methane, organic vapors (solvents), acid gases(chlorine) and ammonia. This area was mostly covered by Industrial Hygienists, Safety Engineers, Mechanical Engineers and Industrial Designers.
In homes, most contractors asked only about allergies or odor problems. Radon was another concern. The solutions were advanced mechanical filters, electronic air cleaners, humidifiers and ER/HR ventilators. Large custom homes usually had an architect involved, so if any thought was given to designing for IAQ, it was likely by them. It was up to the individual contractor to design for and quote IAQ items.
On any jobs I was involved in, I used the ASHRAE guidelines, and manual calculations.1 -
This user has 4 posts all selling the same software....andreea said:I found these free webinar recordings that teach you how to perform CFD and thermal analysis for HVAC systems simulation, including air quality and contamination control applications. They are really interesting, but I was wondering if the majority of HVAC engineers are using simulation in the design phase (of rooms, buildings, garages, cleanrooms). Or do you mostly rely on manual calculations?
Albert Einstein0 -
And on the other sites too
- 15.8K Strictly Steam
https://www.youtube.com/watch?v=anwy2MPT5RE
