Replacing Hot Water Tank
06honda
06honda Member Posts: 15
edited January 2017 in Radiant Heating
I have a 1100 square foot bungalow on slab with infloor radiant heating. 2 zones, hot water is obtained from a 65 Gallon Hot water tank that runs off natural gas. Heating bills are pretty good, the highest month for the past 5 years here in southern Ontario was $135. My plan is to replace the 1999 hot water tank and have considered maybe going with a tankless hot water tank. Upfront cost is much more but my main questions are:
Q1: Will a tankless hot water tank work with my infloor radiant system?
Q2: Will the tankless hot water tank cycle frequently?
  • Ironman
    Ironman Member Posts: 7,886
    Don't do it; you'll regret it!
    Tankless water heaters are not designed, controlled or approved for space heating. The heat exchanger has an enormous amount head that will choke the flow produced by a hydronic circulator.
    Most manufacturers will only warranty them for 3 years or less if used for space heating.
    Use the right tool for the job: a boiler. It will be a lot more efficient than a tank water heater if done correctly.
    Bob Boan
    06honda
  • kcopp
    kcopp Member Posts: 4,636
    I would NOT use a tankless to run your system. Do you also use the water heater to get your domestic hot water?
  • 06honda
    Yes there is just one hot water tank for both. I was not set on getting a tankless but wanted to explore if it was a good idea. I am willing to just replace the current hot water tank with a similar one no problems, way cheaper also. Just as a point the temp that my floor works at is 110 F.
  • Abracadabra
    Sorry.. but whenever I hear "I want a tankless hot water heater" I always think of this:
    https://www.youtube.com/watch?v=vffdymvjluk
    The information may be presented in a silly way but the information is all true.
    06hondaKoan
  • 06honda
    I listened to it, great and true points. Good post.
  • kcopp
    You should really separate the Heating from the domestic hot water.
    A good Modulating boiler w an indirect water heater would be perfect. If space is an issue you could go the combi route. A bit of a trade off w the boiler being oversized but its better tha you have now.
    I personally like this unit.
    http://ibcboiler.com/ibc-products/hc-series/
    06hondaBrewbeer
