Waters not getting hot
durgesh
Member Posts: 3
in Gas Heating
Does anyone know about this issue can't figure out what's wrong with my water heater
I have uploaded two pictures of my heater is anyone out there who can help me ?0
The troubleshooting section of the manual will list the possible causes. Easy first check is the vent outside, is it obstructed or plugged somehow.
Beyond that you will need a meter to run some diagnostics.
Has it been cleaned, serviced and adjusted with a combustion analyzer lately? The burner needs to be properly adjusted and set up to prevent lock outs and inefficient operation.
High tech equipment is a bit more complicated to troubleshoot and required specific tools and knowledge to get "right"Bob "hot rod" Rohr
Living the hydronic dream-1 -
Hi ZAMAN and HOT ROD check everything like u said guys none of them is working0
