Waters not getting hot
durgesh
durgesh Member Posts: 3
Does anyone know about this issue can't figure out what's wrong with my water heater
  • durgesh
    I have uploaded two pictures of my heater is anyone out there who can help me ?
  • Zman
    Zman Member Posts: 7,614
    I would check for vent obstructions and reset the heater...
    Albert Einstein
    durgesh
    hot_rod Member Posts: 27,856
    The troubleshooting section of the manual will list the possible causes. Easy first check is the vent outside, is it obstructed or plugged somehow.
    Beyond that you will need a meter to run some diagnostics.
    Has it been cleaned, serviced and adjusted with a combustion analyzer lately? The burner needs to be properly adjusted and set up to prevent lock outs and inefficient operation.
    High tech equipment is a bit more complicated to troubleshoot and required specific tools and knowledge to get "right"
    durgesh
  • durgesh
    Hi ZAMAN and HOT ROD check everything like u said guys none of them is working
  • JUGHNE
    JUGHNE Member Posts: 11,604
    If the exhaust pipe going outside is clear and open.....and you have pushed the reset button......the next thing to do as it says on the control is to call for service. Maybe someone who does both heating and plumbing and is familiar with electronic ignition.
    durgesh
