Baseboards
insurewithgreg
Member Posts: 3
I have 1 thermostat, 2 level house, my baseboards get hot and work fine on the first level but the baseboards on the 2nd level are cold, no water seems to get to them...please help
What is the pressure and temperature indicated by the gauge on the boiler. A picture of the gauge and then of the boiler with piping would be good.0
Pressure 23 psi...temp 2000
Pressure's OK, temperature is perhaps a bit high. Is there any way to bleed the upstairs baseboards? Sounds like they are air bound.Br. Jamie, osb
Im not sure...just sounds like there isn't any water getting to them0
Do your baseboard heaters look like the one in this video?insurewithgreg said:Im not sure...just sounds like there isn't any water getting to them
https://www.youtube.com/watch?v=N4K9hi7vLnU 0 -
If the element is turned sideways the air will not flow through it and the element will not give up its heat to the room.
Is there new carpet in the rooms that is to thick blocking air from going in the bottom of the baseboard and out the top as warm air?
Can you bleed the air from the second floor baseboard?
Are the dampers on the baseboard open?
If one zone how many feet of element is on the system? What size pipe is supplying the system? How is it piped? One big loop?
monoflow system? What is the water temp leaving the boiler and what is the return temp?
Is the thermostat on the first floor to close to baseboard and thus turning the boiler off before the second floor gets warm?
Some of the pressure gauges are not accurate, seems odd there is no flow with 23 psi. Unless someone drained the system for some reason ane didn't purge the split loop0
- 116 Geothermal
- 169 Indoor-Air Quality
