UPS for hardwired device
ratio
ratio Member Posts: 4,176
Just happened to come across this a few minutes ago. Seems to carry a UL listing, it should answer for controls, even if it's not big enough to carry a pump.
  • NY_Rob
    NY_Rob Member Posts: 1,370
    Looks good.
    I have a kill-a-watt meter on my mod-con.... when not heating/pumping it draws 5 watts, when heating & pumping for all three baseboard zones it draws a total of 50 watts which includes draw from the ECM CH pump (Grundfos Alpha) and the 40va transformer that operates the three z-wave t-sats and Taco Zone Sentry zone valves.
    According to the datasheet for the above 550VA UPS- it would run my whole system while actively heating & pumping for 50 min.
    Sweet!
