Build your own radiator?
MilanD
MilanD Member Posts: 1,162
May be a little utilitarian, but - hey, if it works, it works! Gave me an idea for a short under the window pipe radiator. With some kind of cap to keep it together, this could give a lot of BTUs with a 1' pipe stack.
http://www.builditsolar.com/Projects/SpaceHeating/DawsonRadiator.htm
Nostat2Handlers
  • rorylane
    rorylane Member Posts: 22
    I was thinking about doing something similar to replace a window seat radiator that is long gone. This one is better designed than what I had come up with, less fittings.
    MilanD
    hot_rod Member Posts: 27,442
    I've built a bunch of different radiators over the years. Everything from copper to concrete.
    Hot water circulating through pipes, easy as that. Give it a try and show us your stuff. Here are a couple favorites.
    MilanDJohnNY
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    @JohnNY has posted some tubular steel radiators being used in NYC.
    The only problem with copper is that when it's shiny, it's output is low. I had a sheet copper radiant ceiling heater in my office, and I was seeing like a 2 degree delta across it. I painted it flat white with latex and the delta T jumped to 4 degrees F. Essentially doubled the output with the stroke of a brush.
    Low emissivity...
    ME
    MilanDEcorad
