Radiator air valve no longer fits snugly in the threaded hole
I have a two pipe steam system and a wrought tube radiator. The air valve just spins around and won't tighten properly, resulting in constant steam leakage. I have tried using a 1/8 in. brass nipple with a coupling to accept the air valve, but the threads won't hold. I need a plumber with experience in solving problems like this to repair it for me. Can anyone recommend someone? I live in Cambridge, MA.
  • Abracadabra
    Abracadabra Member Posts: 1,948
    Could use a helicoil insert or some JB Weld and retap it.
    Why do you have an air vent on a 2-pipe radiator?
    Grallert
  • Fred
    Fred Member Posts: 8,542
    Two pipe systems typically don't have vents on the radiators. Anyway, most of us drill and tap the hole to accept a 1/4" to 1/8" bushing.
    Grallert
  • ChrisJ
    ChrisJ Member Posts: 15,714
    This is what I'd do.
    McMaster Carr has nice nickel plated 1/4" to 1/8" NPT bushings that work good.
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • KC_Jones
    KC_Jones Member Posts: 5,739
    Post a picture of the rad so we can see both connections. If it's true 2 pipe system it isn't supposed to have vents at all. There is a 2 pipe air vent system and the picture will tell us which one you have.
    2014 Weil Mclain EG-40
  • Mad Dog_2
    Mad Dog_2 Member Posts: 6,988
    Uh...oh...this is how that radiator valve in the Bronx probably blEw off. No good. the first thing I would try history clean the thread a little bit with a tap and then try a black nipple in the hall and see if that's loose. ,if it's still wobbly, retap To a a quarter inch thread. don't take any chances Mad Dog
  • scottdoughty
    scottdoughty Member Posts: 6
    Thanks for your comments. I believe my two pipe steam radiators do not have traps, so the vents are necessary to get rid of air. My first time posting to this site. I'd like to attach pics, but I don't see a button to do that. I like all the ideas presented. I think I'll drill it out for 1/4" and tap it, then use a 1/4-1/8 bushing. Should work, and is pretty straight forward.
    Any cautions I should be aware of when I drill it out?
  • Fred
    Just take your time and keep your drill and tap level and straight. Use the right size bit.
  • Sailah
    Sailah Member Posts: 826
    If you don't have traps on your 2 pipe system why would the air go through a tiny air vent vs the 3/4" pipe on the radiator outlet? Do you have orifices or something similar?
    When you post a message there is an icon right of center that looks like a dog eared piece of paper. That allows you to post pics.
    Peter Owens
    SteamIQ
  • Koan
    Koan Member Posts: 439
    Sounds like you should have someone look to see how the piping is done as well. Two pipe systems usually do not have radiator vents. It may be you have traps of which you are unaware, or someone installed a vent where one should not be.
    Might be best to do nothing until you can post a picture.
    To post a picture click on the icon that the blue arrow points to in the menu above immediately under the words
    "Leave a Comment" 3/4 from the left as indicated in this picture.
    Have you ever drilled and tapped a hole before? If not, maybe you can find a mechanic or a friend who has some experience to do this.
  • Sailah
    Peter Owens
    SteamIQ
  • scottdoughty
    Thanks. That's the way I plan to approach it.
  • scottdoughty
    I've drilled and tapped holes before, but it's been awhile, and perhaps never on a tube. I feel confident about it though. I don't know about the no air valve on two pipes systems, but I will mention it to my plumber. He's been schooled on steam systems, and he's never said there shouldn't be air valves. I think they've been in place for nearly 100 years with no problems. I've been in this house for 29 years with no problems until this ill fitting air vent reared its ugly head.
  • ChrisJ
    I thought there were a few 2 pipe vented systems early on?
    @Dan Holohan
    Jamie Hall Member Posts: 23,343
    Ah... I wouldn't guarantee it, but the photo sure looks as though you could indeed be looking at one of the early two pipe with air valve systems... valves at both ends and an air vent... they do exist.
  • ChrisJ
    What are you, Santa and the M&Ms? :)
  • Double D
    Double D Member Posts: 442
    Two pipe air vent systems.
  • Koan
    sounds like drilling and re-tapping is the way to go. Drill slowly being careful to hold 90 degree angles with some lubricant. Try to let as little of the the lubricant as possible get into the radiator. Get a good quality tap. Like @Fred said---take your time.
  • scottdoughty
    Thanks Fred. I've got the air valve stabilized with a 1/8" nipple with a coupling, but I know it is only temporary. I will drill and tap it in the spring when the weather is not severely cold just in case I screw it up and have to call a plumber to replace the radiator. I appreciate your suggestions and I will cover all of them very carefully. I already bought a new 7/16" bit and a good 1/4" tap from a plumbing supply store for the job. I'm confident, albeit cautious.
