replacement for a Lennox HS29-511-1p 4 ton a/c unit.
robertelee
Member Posts: 1
Any suggestions?
Find a GREAT dealer who will do a load calc to confirm that 4 tons is really the correct size. Then take their suggestion for a brand. In a cooler climate, super SEER isn't critical. In the south with long cooling seasons, a high SEER might be worth it. Ask about possible utility rebates and tax credits for a middle efficiency model.
Don't go for a builder line unit, mid grade are better built. If in a cold climate, Rheem, American Standard/Trane, York and some Lennox units use demand defrost systems that eliminate 100s of unnecessary defrosts each season.1 -
That's a straight a/c unit which has probably out lived it's life expectancy.
You will HAVE to replaced the indoor section to match up with a new unit.
Take John's advice and find a good pro. Check the contractor locator on this site.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
