LAARS Endurance 175
Allyson
Member Posts: 2
My boiler is short cycling and Kettling. The heat is fine but the hot water only lasts about 1 minute and then goes cold. The temp reads 162 and shoots up to 213 and back again in minutes.
It sounds like a lack of flow to the DHW heat exchanger. Every system is set up differently. Do you have any pictures?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Sounds like your internal pump has gone bad. It's a very easy fix. Just open the door on the unit take a pic of the round black or blue grundfos pump and send the pic to your heating guy. He will bring one with him and test the one you have to make sure it's bad. Typically that is what will cause your problem, but I have been wrong before.Tom
Montpelier Vt0 -
I just dealt with a Laars EB110 Endurance boiler. 12 yrs old. Propane fueled. Early "condensing" type. Terrible machine. I did internet research. Attempted to contact tech support. Terrible results. Seems the boiler is Russian made. Opened it up looked inside the wiring was like spaghetti inside the cabinet. Overheated and crispy in many different places. Too many connections were dubious. Replaced an expensive flow switch for DHW heat exchanger. No luck. Supply houses all offer no help. Will be replacing the boiler in a week or so.0
Made in Russia? No.0
Russia. Korea? You tell me.
I just ordered a flowswitch from Parts4heating.com HERE is information from their website:
Teledyne Laars Endurance Parts
At Parts4Heating.com we sell a variety of Teledyne Laars Endurance boiler parts for both old and new style EDP and EBP boilers. Our inventory of Endurance parts range from gas valves to blower assemblies and everything in between. If you have any questions about our inventory of Endurance replacement parts, don’t hesitate to give us a call at 1-800-536-1582 and speak to one of our Endurance parts experts today!
EDP (Old Style, Blue) EBP (Old Style, Blue) EBP (Russia)
The Laars Endurance EDP Heater is a blue and beige heater that was manufactured prior to January 2005.
The Laars Endurance EBP heater was manufactured prior to January of 2005 and was replaced by an identical more efficient model.
EDP (New Style, Gray) EBP (New Style, Gray) EBP (Korea)
This appliance is a low pressure, direct vent, cold start hot water boiler that provides heat for hydronic space heating. This particular model has been in production since January of 2005.
This appliance is a low pressure, direct vent, hot water boiler that provides priority domestic hot water on demand as well as hydronic space heating system. This unit began production in January of 2005.
They sell models TO Russia and Korea. It's made in the U.S.A. I've been to their plant in NH.0
That's distressing to learn. I live in VT and could get no help from tech support. Installing another boiler w/ good support.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
