Radiant element only partially glowing
Guest100
Member Posts: 2
Hi. I have a Broan 178-A in wall radiant forced air heater. It is in a bathroom with room temp about 50 deg and when I turn it on, only 20 percent or so of the element glows. I am wondering if this is normal or if the entire element should be glowing equally. It is putting out heat and feels ok but I would think in this cold temp it would glow full force as it heats the cold room. I have looked over the element thoroughly and the wire looks good, clean, no breaks or decay. Attached is a photo (rotated to the right) with the glowing areas circled. Thanks for your help.
Fan forced, I presume. This probably completely normal -- the heating element doesn't have to be glowing to be putting out heat, and the cooler the air being blown on it by the fan, the less element will be glowing. In fact, I would be inclined to try and find out if anything (dust, grime, what have you) is blocking the air flow to the parts of the element which are glowing, and clean it up.Br. Jamie, osb
Yes it is fan forced and yes the heater is putting out heat and seems normal. It is in an empty rental (that's why it's so cold) and after cleaning the heater and replacing the thermal overload i just noticed the element and thought it looked a little strange. Thanks for your comments - much appreciated.0
We all thank you for the feedback!0
