Best Method for finding broken underground steam pipes and dry or wet returns
I was thinking a thermal imaging camera would be good for this.... any experience would be appreciated.
  • ratio
    ratio Member Posts: 3,955
    I've used a Fluke VT04 with smashing success for the very purpose.
    I hear a cat also works.
    EBEBRATT-Ed Member Posts: 17,568
    I have herd the cat story as well, or walk around with bare feet,
  • Danny Scully
    Danny Scully Member Posts: 1,461
    edited December 2016
    What is your intent here @The Steam Whisperer (Formerly Boilerpro)? Sorry to respond to a question with a question, but my approach has always been, if there's a leak anywhere in the wet return piping, whether it's buried or not, it's time to propose complete replacement with isolation/purge valves (obviously every job has its variables, but you get the idea). Then again, you may just be asking to ask.
  • SWEI
    SWEI Member Posts: 7,348
    A thermal imager works wonders for this. We found a leaking hot water pipe in a slab last year that had stumped multiple contractors over a 20-year period.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,872
    I've used just about every type of leak detection there is, and infrared seems to have the highest return on the investment.
    The only other "guaranteed" method, is helium leak detection, and it's fairly expensive. Plus you'd have to figure out how to block the escape of all means of escape.
    ME
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,262
    It sounds like I have another reason to buy a new tool.... an IR camera. Any other recommendations for models useful for a variety of uses...ie checking traps etc. Also, I agree, Dan, that the complete lines should be replaced. HOwever, you know how that is....you can talk until your blue in the face and not get anywhere in many cases. Also, how well do the cameras work on really low temperature return lines ? We've upgraded a number of 2 pipe systems to orifice plates and the returns run very cool....like 80 to 100F?
    And Mark, never heard of helium testing, but that could get challenging capping all the connections.
  • Canucker
    Canucker Member Posts: 723
    @The Steam Whisperer I recommend getting yourself one of these for Christmas. I use mine a lot because I always have it on hand
    http://www.gsmarena.com/cat_s60-7928.php
    You can have it good, fast or cheap. Pick two
  • Grallert
    Grallert Member Posts: 955
    I've been using a Flir One for my Iphone with an extension adapter. I use it to see failing f&ts traps etc. It's been a handy tool for me. And it doesn't break the budget.
  • Sailah
    Sailah Member Posts: 826
    I really want one of those CAT smartphones.
    I do like my FLIR E4 very much but it's not a cheap date.
    Peter Owens
    SteamIQ
  • BobC
    BobC Member Posts: 5,521
    The cat smartphone is a little dear also, How about the Flir 1 attachment for Iphone or android phones, that can be had for a little over $200 if you look around.
    Bob
    3PSI gauge
    Grallert
  • Grallert
    This from my Flir One. It's a good intro to IR I think. though I have no experience with the higher end tools. Its very helpful for my purpose.
  • Sailah
    Here's a screenshot of my E4 that was upgraded to E8 specs
    Peter Owens
    SteamIQ
  • Canucker
    By the time you get the phone and add the flir attachment, you aren't far from the price of the Cat S60. Now drop your phone from 6 feet high onto concrete and then go toss it in a pool. Think it'll still work? I know that Cat phone will. That's the difference in price. Not worth it for someone that doesn't need it but if you do... priceless B)
  • Sailah
    That's kinda the way I look at it. There aren't free phones anymore, any of the newer class phones are $500+. I do think thermal imaging is a great tool. I use my FLIR all the time and would probably use the CAT phone even more because it would be on me. The FLIR has its own briefcase and not really pocketable. But I believe the imager in the FLIR 1 is the same as in the CAT phone.
    I need a new phone anyways had mine for years so maybe I'll spring for it.
    Peter Owens
    SteamIQ
  • ttekushan_3
    ttekushan_3 Member Posts: 963
    Confirmed. A cat will work.
    Terry T
    Canucker
