Condensate pump
StephenJanowski
Member Posts: 1
When would I need a condensate pump on a steam system? I can understand why to use a boiler feed tank but I can't think of any situation why a condensate pump would be needed. I ask because I looked at a job that has one and I want to get rid of it. It is a residential two pipe system. I have installed bigger boilers on much larger systems without installing a condensate pump or boiler feed tank and never had an issue.
In my humble opinion, the only time one would need a pump on a residential two pipe system is if, for some reason, the boiler was placed above some of the radiation. Then you'd need something to get that condensate back to the boiler. Otherwise... I can't think of a good reason.
Just make sure that all your condensate can, in fact, make it back to the boiler by gravity!
And if one ever did have one, it should be controlled as a boiler feed pump, not as a condensate return!Br. Jamie, osb
usually if its sitting next to a boiler you dont need it. If the water could make it back to the condensate tank, it should be able to go another five feet to the boiler. There are times when they are needed, but for specific reasons like not enough 'b' dimension, as is the case with my system.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
I have one now! Those photos are just over a year old.Abracadabra said:
no skim port @zackwatt ?
It was one of the first things I changed after going through this site.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
