Condensate pump
When would I need a condensate pump on a steam system? I can understand why to use a boiler feed tank but I can't think of any situation why a condensate pump would be needed. I ask because I looked at a job that has one and I want to get rid of it. It is a residential two pipe system. I have installed bigger boilers on much larger systems without installing a condensate pump or boiler feed tank and never had an issue.
    Jamie Hall Member Posts: 26,838
    In my humble opinion, the only time one would need a pump on a residential two pipe system is if, for some reason, the boiler was placed above some of the radiation. Then you'd need something to get that condensate back to the boiler. Otherwise... I can't think of a good reason.
    Just make sure that all your condensate can, in fact, make it back to the boiler by gravity!
    And if one ever did have one, it should be controlled as a boiler feed pump, not as a condensate return!
  • gerry gill
    gerry gill Member Posts: 3,083
    usually if its sitting next to a boiler you dont need it. If the water could make it back to the condensate tank, it should be able to go another five feet to the boiler. There are times when they are needed, but for specific reasons like not enough 'b' dimension, as is the case with my system.
    gwgillplumbingandheating.com
    SWEI
  • zackwatt
    zackwatt Member Posts: 81
    You mean like mine? lol
    LionA29
  • Abracadabra
    Abracadabra Member Posts: 1,949
    no skim port @zackwatt ?
  • zackwatt
    I have one now! Those photos are just over a year old.
    It was one of the first things I changed after going through this site.
