Cyclegard LWCO
kcopp
Member Posts: 4,432
Does anyone know if you can disable the "intermittent level test" feature on the CG400 ?
Its a real pain trying to get the unit to produce steam only to have it stop for a few minutes.....every few minutes.
No, the SafeGuard is the same control WITHOUT that nonsense. I'm going through this with Burnham right now on the two MegaSteams that we twinned. The controls don't even time the same which is causing added problems. See my thread on New MegaSteams in an Old Church.kcopp said:Does anyone know if you can disable the "intermittent level test" feature on the CG400 ?
@adambnyc
They're both HydroLevel: the Safeguard is the one that he needs.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.-1 -
model #? please....0
@Ironman whoops. Totally right. I was saying the brand name.
I believe this is the droid your looking for.
http://www.supplyhouse.com/Hydrolevel-Safgard-450-Electronic-Low-Water-Cutoff-120V-Stea?gclid=CjwKEAiAyO_BBRDOgM-K8MGWpmYSJACePQ9C9h0a0XdIYGDvN_NnXVemEWF3N_-NxG7VhBUXwpa-YBoChejw_wcB
Quick question. Do you wire these 120v separately than other controls that are low voltage? Or does it still get wired the same because of the transformer ?
I'm god awful with electrical and wiring all the controls.
Harry.0 -
The Safgard 400 is for 24 volt steam systems and the VTX-24 is the water feeder that is 24 Volt.hboogz said:Quick question. Do you wire these 120v separately than other controls that are low voltage? Or does it still get wired the same because of the transformer ?
Harry.1 -
One more time but with the 24v version. This probably resembles very closely what you have with the cycleguard. Should be plug n play
http://www.supplyhouse.com/Hydrolevel-Safgard-400-Electronic-Low-Water-Cutoff-24V-Steam?gclid=CjwKEAiAyO_BBRDOgM-K8MGWpmYSJACePQ9Cz-XnTRIuFZisaDsmEQCblkDUEyOkEJv2zn4VybbzFBoC8Srw_wcB
Thanks Fred! I take it these are the lwco and feeder combo preffered? I recently went with the McDonnell Miller unimatch and lwco combo.0
@hboogz , yes, the Safgard and the VTX (with digital water meter) are the LWCO and auto feeders that most of the Pro's and HO's on here prefer. I personally have the McDonnell Miller #67 LWCO and I removed the McDonnell Miller water feeder in favor of manually adding water if/when needed as the MM auto feeder doesn't have a water meter and you don't know when you might have a leaks somewhere. I'm sure, when the time comes to replace my boiler, I will move to a probe type LWCO and a Safgard or similar.1
I would like to do this on my boiler as well. Are there any advantages, pros/cons, to the Hydrolevel Safguard 400 vs. the 450? What do the installers mostly use or recommend?Crown Boiler Bermuda Series model: BSI103, BTU output: 85,000, single pipe steam system0
@Fred, I looked up my voltage, yup 24V, so the 400 is the one I need. Thank you.Crown Boiler Bermuda Series model: BSI103, BTU output: 85,000, single pipe steam system0
I suspect there is a way to disable it. When I enabled the "SmartCycle" feature on mine the Intermittent level test stopped working. It started again at the beginning of the next heating season.Just another DIYer | King of Prussia, PA
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
