dead end & DHW expansion tank
Boon
Member Posts: 261
Just read another thread that mentioned dead ends & Legionella. Now I'm freaking out about the 9" of pipe to my DHW expansion tank being a dead end. Is 9" to an DHW expansion tank too far? The inspector noted the tank during the rough-in inspection but didn't say anything else about it.
DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.
Is the expansion tank for your boiler that heats your home?? or is it an expansion tank on the hot water heater that heats domestic hot water for showers etc.??
If it is a boiler expansion tank than a dead end isn't a problem.
Use two 90 and a tee to make a hairpin curve if you need the 9" for clearance.
Actually, 4 90s0 -
9" isn't enough of a dead end situation to be a problem if it's on a well pump water line. Remember that about a third of that tank volume will move in and out with each cycle of the well pump.
You say that this is on your domestic hot water line, though, so I presume that this is not a pump control pressure tank, but on there because there is a pressure reducing valve or check valve between you and city water? Even so, it shouldn't be a problem. In comparison with the amount of hot water used the amount moving in and out of that pipe and tank is tiny.Br. Jamie, osb
Guess I'm going blind he did say it was a DHW expansion tank.0
Yes, I should've said that originally.
I'll stop worrying but now I see a different way to mount it so maybe I'll move it in the future. ThanksDIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.0 -
Looks like products are being developed to address "dead-ending" of DHW expansion vessels.
Living the hydronic dream1 -
Dam, why didn't I think of that. If I did I could retire!!!!!
Said that 1000times0 -
Those should work very well. Jacuzzi made a variation on that, years ago. Haven't seen it lately.Br. Jamie, osb
- 50 Industry Classes
