Pex, Pex, Pex
Tony Massi
Member Posts: 86
in Plumbing
I'm old school and used about a million feet of copper in my life. Now Pex is just about everywhere. Its not really Pex its anything that uses a plastic tube they call it Pex. I guess back in the day when copper was first being used the old timers said that stuff will never last and had a dozen reasons not to use it. Anyway I have to replace some baseboard heat and want to just use Pex from the element down into the floor and not copper to Pex under the floor.
I know this customer will complain if they see orange or red tubing for that short spot going into the floor. I was thinking of painting it with spray paint. Has anyone has this experience painting the Pex?
Realistically, there is nothing you can paint on polyethylene that will reliably and durably adhere to it. The slipperiness of the material is a big part of what makes it work so well across a broad range of fluid conditions. Sleeves might be a good option.
White hePEX with F1960 fittings & rings trims out fairly clean as long as it's not too long (at which point keeping it straight can become an issue, hence PEX-Al-PEX.)0 -
I'd be leery of using any kind of paint on plastic without mfgrs approval. Perhaps a short sleeve of copper could be slid down before the termination is applied?0
There are some vinyl snap around covers for covering the pex.
Heat shrink tube comes in a lot of colors, slip a piece over the pex and warm it with a hair dryer.
Or transition to copper below the floor.Bob "hot rod" Rohr
Living the hydronic dream-1 -
Hmm, we install pex pipe aswell, this has worked for us before but you should try this on a test peice... take a bit of girtty sand paper, quickly go over the pex just to rough it up ( an x patern is the best, this will allow the paint to stick) and use a spray paint with a primer in it. This shouldn't be too much of a hassle if its a smaller piece.0
I would stick to the snap on cover pieces of plastic. I would be concerned that sanding the pex would damage the oxygen barrier.
Look here down on the page 7.
http://www.hydronicalternatives.com/getattachment/49d1bdaf-bb98-42af-8dbc-46d3d6826eed/Radiator-Accessories-Price-List1 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
