Help circulator pump to r845a
kmar35
Member Posts: 6
Hi had a new gas steam boiler installed (crown ) and the plumber never got the baseboard heat that was running fine before working he replaced the circulator pump a taco but I've been trying to trouble shoot with no luck. Turn the tstat on and it clicks the relay but no power to the pump. Have power to terminal 1. Any advice is greatly appreciated trying to get the heat on for the in-laws who are coming to visit!
Is there a jumper between 1 & 3?....you should get plumber to come back...you paid him right?ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
No jumper between 1 and 3 is that what I'm missing? Thought that is what the relay switched on. I would rather deal with it myself then call him back he did a good job on the boiler but was always hard to get back once it was "done" got a better plumber since but trying to save $$ I just unscrewed the screws on pic0
Its wired wrong....if the bx on the left is going to the pump.....put the white wire thats one term 4 to term 2 thats your nuetral to the pump....put a jumper between terminal 1 & 3 and switch the black wire from terminal 3 to terminal 4 (thats your hot to the pump)....where are the screws for the terminals? Also this is not going to turn on the boiler just the pump....theres no wires on terminals 5 & 6 for a boiler enable with a aquastatASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company2 -
5 and 6 are blank and 3 and 4 are to the circulator 3 is going to the white on pump and 4 is going to yellow0
null
The bx on the left is the power number 1 has 120 the bx on the right is the pump0 -
Wire it the way i stated above....put the 2 white wires on terminal #2.....put the black wire from the pump to terminal #4.....put the other black wire (120v hot) to terminal #1 and put a jumper between terminals #1 & #3....ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Paul previously it never kicked on the boiler it would only go on if the boiler was on it heats a very small room. So I will jump 1 to 3 and see if i get power to the pump0
Exactly, if you have a low temp option on the boiler controller land 5 and 6 therePaul S said:Its wired wrong....if the bx on the left is going to the pump.....put the white wire thats one term 4 to term 2 thats your nuetral to the pump....put a jumper between terminal 1 & 3 and switch the black wire from terminal 3 to terminal 4 (thats your hot to the pump)....where are the screws for the terminals? Also this is not going to turn on the boiler just the pump....theres no wires on terminals 5 & 6 for a boiler enable with a aquastat
Albert Einstein1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
