Al294C Stainless, at local vendors?
GW
Member Posts: 5,177
in Gas Heating
I need some heating help, we serviced a Viessmann Vitodens, the original installer ran SS pipe to the chimney and (assuming!) ran it up the flue. The rep says Al294C Stainless is fine. I could call the local vendors to see what SS they have. but was hoping I could get a faster answer to a hypothetical question here. I don't want to call the management co with a possible concern until i have just a wee bit more info.
So, the local vendors (that sell heat fab/ Z flex), do they 'typically' have the Al294?
Thanks Heating Guys
Thanks Heating Guys
Jensen Mechanical (New Hartford, CT) 1-860-738-2800 sells it and is a factory rep for (I forgot what brand) sizes and designs a lot of stacks for the larger commercial jobs. expensive stuff
I don't believe any of the supply houses handle this stuff0 -
Ok I'm trying to figure out when I should open my mouth on this or keep it shut. At first I thought it might have been a complete mistake. Then I learn a certain type of stainless is ok. I never would have thought someone would use stainless on a condensing boiler when plastic would seemingly do a better job. The local vendor that sells heat fab and z flex, does that qualify or no? I wish I knew then what I know now I would have made notes on the existing SS. If the locally-purchased stainless does not qualify, I may need to open my month.0
Ahhhhh didn't read slowly enough, Tim, the heat fab and z flex at the local vendors is AL294?0
You have to read the certified I & O manual of the boiler to find the acceptable material. Tim, on certain higher BTU boiler the manufacturer specifies AL29-4C. They are cat IV or can be Cat II. They are all above 87%. At one point we were the largest purchaser of Al29-4C. We then went multiple boiler and use S636 PVC ( SCH40 PVC with a different colour!)0
