My next mission in life
Steve Minnich
Steve Minnich Member Posts: 2,868
is to replace this failed Munchkin and most of its near boiler piping. For some reason the piping, pumps, mixing valve, zone valves, air separator were all installed at ceiling level. The existing P/S piping was closer to being right than most that I see. The new equipment will include a Lochinvar Knight Fire Tube with a 30 gallon buffer tank and Grundfos Alpha pumps. Not even close to Harvey's next project but I'll take it.
Steve Minnich
GordyIronman
  • njtommy
    njtommy Member Posts: 1,105
    Cant wait to see the finale pictures.
  • Steve Minnich
    I've got an entire 15' wide X 9' high adjacent wall to work with. Everything is coming down from the ceiling, where it would be difficult to service, to the wall. And the boiler is the WHN wall mount as well.
    Steve Minnich
  • njtommy
    Plenty of room to show off some nice pipe porn.
  • kcopp
    kcopp Member Posts: 4,630
    edited February 2016
    Why did the Munchkin fail/ have issues?
    What are the emitters upstairs? CI?
  • Steve Minnich
    My first time on the job was to offer solutions for the replacement. It's 12 years old. HX leaks.
    Steve Minnich
  • Steve Minnich
    @kcopp - 3 fan coil zones and 3 radiant zones.
    Steve Minnich
  • jpcallan
    jpcallan Member Posts: 15
    Is the Munchkin leaking boiler water or condensate?
  • Steve Minnich
    It's not leaking anything now. It was replaced in February. It was leaking boiler water.
    Steve Minnich
  • njtommy
    Well how did the job turn out?
  • Steve Minnich
    Not bad. This is it at about 95% complete. I think I just had to mount the Taco mixing valve.
    Steve Minnich
    njtommyPaul S_3Solid_Fuel_Mantim smith
  • njtommy
    Looks great!
    Steve Minnich
  • jpcallan
    A very polished job. Well done. They should all be so photo-worthy.
    Solid_Fuel_ManSteve Minnich
  • Steve Minnich
    Thank you! We just found out yesterday that we won Lochinvar's VIP Installation Showcase on another job.
    Steve Minnich
    rick in AlaskaSolid_Fuel_ManGordy
  • njtommy
    That's awesome. I think I saw that on face book.
    Steve Minnich
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    beautiful job!!!! @Stephen Minnich
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
    Steve Minnich
    EBEBRATT-Ed Member Posts: 19,621
    really nice job!!
    It's a shame to have to replace equipment that isn't that old. Is this the future?
    When I started in the 70s we replace old inefficient CI boilers that had lasted 50, 60, 80 years. Now we are replacing 10-15 year old equipment'
    It's much more efficient but what's the point if the mod cons are 10 year boilers??
    Guess we will have to wait and see.
  • Steve Minnich
    Mark alluded to it, annual maintenance is a must. Better installations wouldn't hurt either.
    Steve Minnich
    Paul S_3Canuckerdelta T
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    @Stephen Minnich if something were ever to happen to me and my family needed mechanical work done....you would be on the short list. I DO NOT say that lightly :smiley:
    Beautiful work as usual, truly one of the bar-setters here!
    Taylor
    Paul S_3Steve Minnich
  • Tom_133
    Tom_133 Member Posts: 964
    Stephen,
    As always looks great! Quick question, I noticed no isolation ball valves after the sentry zone valves, are you doing that because you should never have to remove them? I always have put them there, doesn't mean I need to, in fact I would love to get away from doing it.
    Tom
    Montpelier Vt
  • Steve Minnich
    Tom - in my experience, a very high percentage of zone valve failure is in the head or actuator, assuming the body wasn't cooked when soldering. If it were W/R 1311''s, I'd have valves everywhere
    Steve Minnich
    Hatterasguy
  • NY_Rob
    NY_Rob Member Posts: 1,370
    edited November 2016
    Stephen- as others have already stated- beautiful job!
    I noticed you have both Alpha's in "Auto" mode... does this work out for you normally?
    I'm still trying to dial mine (alpha w/HTP UFT-80 mod-con) in and have been experimenting with different modes on the Alpha.
    If you don't mind me asking- what kind of flow were you seeing at 10-11 Watts? I'm seeing 2gpm at 14 watts.
    Thanks...
    Steve Minnich
  • Solid_Fuel_Man
    And...why is the actuator off the i-series 3 way? Inquiring minds must know!
    I still love to see soldered copper as opposed to press, looks cleaner, as well as the strut and cushion clamps.
    Taylor
  • Steve Minnich
    As I said earlier, the mixing valve wasn't mounted yet because the job wasn't finished yet when I snapped that pic. It just happened to be the first picture I saw when someone asked to see it. LWCO wasn't connected yet either. And yes, Auto has worked well for us across the board.
    Steve Minnich
  • NY_Rob
    ^ thank you!
  • Solid_Fuel_Man
    Oh whoops I didn't even see that you wrote that in your post...I was too enamoured with the install pic ;)
    Taylor
    Steve Minnich
  • hvacfreak2
    hvacfreak2 Member Posts: 500
    Fantastic job , looks well thought out and executed for real .
    hvacfreak
    Mechanical Enthusiast
    Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
    Easyio FG20 Controller
    Steve Minnich
