My next mission in life
Steve Minnich
Member Posts: 2,868
is to replace this failed Munchkin and most of its near boiler piping. For some reason the piping, pumps, mixing valve, zone valves, air separator were all installed at ceiling level. The existing P/S piping was closer to being right than most that I see. The new equipment will include a Lochinvar Knight Fire Tube with a 30 gallon buffer tank and Grundfos Alpha pumps. Not even close to Harvey's next project but I'll take it.
Steve Minnich
2
Cant wait to see the finale pictures.0
I've got an entire 15' wide X 9' high adjacent wall to work with. Everything is coming down from the ceiling, where it would be difficult to service, to the wall. And the boiler is the WHN wall mount as well.Steve Minnich0
Plenty of room to show off some nice pipe porn.0
Why did the Munchkin fail/ have issues?
What are the emitters upstairs? CI?0 -
My first time on the job was to offer solutions for the replacement. It's 12 years old. HX leaks.Steve Minnich0
Is the Munchkin leaking boiler water or condensate?0
It's not leaking anything now. It was replaced in February. It was leaking boiler water.Steve Minnich0
Well how did the job turn out?0
Not bad. This is it at about 95% complete. I think I just had to mount the Taco mixing valve.
Steve Minnich4 -
beautiful job!!!! @Stephen MinnichASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company-1 -
really nice job!!
It's a shame to have to replace equipment that isn't that old. Is this the future?
When I started in the 70s we replace old inefficient CI boilers that had lasted 50, 60, 80 years. Now we are replacing 10-15 year old equipment'
It's much more efficient but what's the point if the mod cons are 10 year boilers??
Guess we will have to wait and see.0 -
@Stephen Minnich if something were ever to happen to me and my family needed mechanical work done....you would be on the short list. I DO NOT say that lightly
Beautiful work as usual, truly one of the bar-setters here!
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Stephen,
As always looks great! Quick question, I noticed no isolation ball valves after the sentry zone valves, are you doing that because you should never have to remove them? I always have put them there, doesn't mean I need to, in fact I would love to get away from doing it.
Tom
Montpelier Vt0 -
Stephen- as others have already stated- beautiful job!
I noticed you have both Alpha's in "Auto" mode... does this work out for you normally?
I'm still trying to dial mine (alpha w/HTP UFT-80 mod-con) in and have been experimenting with different modes on the Alpha.
If you don't mind me asking- what kind of flow were you seeing at 10-11 Watts? I'm seeing 2gpm at 14 watts.
Thanks...-1 -
And...why is the actuator off the i-series 3 way? Inquiring minds must know!
I still love to see soldered copper as opposed to press, looks cleaner, as well as the strut and cushion clamps.
As I said earlier, the mixing valve wasn't mounted yet because the job wasn't finished yet when I snapped that pic. It just happened to be the first picture I saw when someone asked to see it. LWCO wasn't connected yet either. And yes, Auto has worked well for us across the board.Steve Minnich0
^ thank you!0
- 167 Indoor-Air Quality
