An interesting iso flange
hot_rod
Member Posts: 26,586
From Calefactio up in Montreal. I did see this a few years back at AHR, sounds like it is on the market now.
You could also put a "Petes" plug in those taps and read pressure and or temperature or hook an accurate balance differential gauge across the pump.
Never seen Calefactio before. Is it a cousin of Caleffi?Bob Boan
Latin root, "heated"
No relation to Italian Caleffi, name or brand.Bob "hot rod" Rohr
Should have known: calorie, calore` = heat.
Thanks, HR.Bob Boan
