An interesting iso flange
hot_rod
hot_rod Member Posts: 26,582
From Calefactio up in Montreal. I did see this a few years back at AHR, sounds like it is on the market now.
You could also put a "Petes" plug in those taps and read pressure and or temperature or hook an accurate balance differential gauge across the pump.
Harvey Ramerkcoppdelta T
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,080
    Nice. I'm seeing an access for glycol/inhibitor maintenance too.
    delta T
  • Ironman
    Ironman Member Posts: 7,857
    Never seen Calefactio before. Is it a cousin of Caleffi?
    Bob Boan
    Latin root, "heated"
    No relation to Italian Caleffi, name or brand.
  • Ironman
    Should have known: calorie, calore` = heat.
    Thanks, HR.
    Bob Boan
