A project with pipes.
Harvey Ramer
Member Posts: 2,290
Nothing to do with heating, but a lot of fun, nonetheless! This is my first pipe project.
4
@Harvey Ramer that is pretty cool stuff-1
And you can even screw it down so it won't tip over in an earthquake! Doesn't get much better.
Consulting-1 -
Thanks guys! It was a lot of fun to make! All the threads have locktite on them so there is no danger of unwanted rotation. Well, except for the floor flanges that serve as the 4 legs. I left them loose for leveling purposes. I glued some felt to the bottom so they wouldn't scratch the floor. All the shelves and top is made from clear cedar with a lacquer finish. I cleaned the pipe with lacquer thinner and then sprayed a couple coats of lacquer finish on them so nobody gets dirty paws from touching. Because people touch everything they see.1
What is that, 3/4"?
Only a noob builds a shelf out of 3/4. A real artistic works only in 1/2" or 1", everyone knows that.
Sorry. reminded me of an episode of Green Acres where they accuse him of having a fake piece of art because it was built out of the wrong size pipe. The artist was strictly a 1/2" man or something.
It looks really good @Harvey Ramer To be honest, I want one now. Did you do the woodwork as well? You could do matching end tables, coffee table etc as well.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
-1 -
Haha, @ChrisJ It's 1" pipe with all American fittings. Does that make me not a noob?
And yes, I did the wood work. There are some flaws but I won't bother to point them out.1 -
Yep, sure does.Harvey Ramer said:Haha, @ChrisJ It's 1" pipe with all American fittings. Does that make me not a noob?
I noticed the Ward fittings immediately.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I'm going to guess intended purpose. Shoes, and gloves.?0
Correct you are.0
Hmmm I like it. However I couldn't put more than dress shoes on that fine piece.0
Sounds like the next project will be a side piece for work boots.0
Hydronic Boot dryer sounds like a good idea to me Chris.0
One of the best things I ever got was my boot dryer.0
Very nice work, piping and woodworking. A cross dresser:)Bob "hot rod" Rohr
There is some serious coin being made out there with those types of ideas.
www.industrialreclaim.comSteve Minnich0 -
I am confused, which is the supply and return. Won't the wood block flow?0
@Jason
That, my friend, is a trade secret. I'd have to kill you if I told you.
@hot rod
Thanks!
This piece is neither cross nor is it a dresser
@Stephen Minnich
I know I dumped some serious coin into making it! If you don't have anything to do sometime, check the price of clear cedar. I could never sell it for what I have in it. I plan on making it a gift to someone.0 -
Industrial is the trend.
Bowling alley. 12 bucks a foot. Up to 20' lengths. 2 1/2" thick 3' 6" wide. Never realized different sections of the lane go from maple to spruce.2
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
