What If The Boiler Had Been 3" Taller?
New England SteamWorks
Member Posts: 1,529
You have to wonder how they would have piped it....
newenglandsteamworks.com
Being a Burnham, you guess what ails her...
Time for a Weil 80:
newenglandsteamworks.com0 -
Looking good!! good job cleaning up that mess.
That #63 MM on the old photo looks like it was pretty low........maybe just the photo angle0 -
We Gerry Gilled the buried returns:
newenglandsteamworks.com4 -
Another beauty @RI_SteamWorks !!0
All dressed up now...
newenglandsteamworks.com1 -
@RI_SteamWorks, That's two separate controls headers? With just an up & over & down to trap them, no piggy tail? Nice. Do you find you have to prime it with water, or does it fill up find by itself?0
Thank you. Yes, two separate, and it primes itself.ratio said:@RI_SteamWorks, That's two separate controls headers? With just an up & over & down to trap them, no piggy tail? Nice. Do you find you have to prime it with water, or does it fill up find by itself?
@RI_SteamWorks Beautiful install as always0
Agreed. But why the float-type LWCO? The 80 series is tapped for probes.......EzzyT said:@RI_SteamWorks Beautiful install as always
Consulting0 -
Ha. You'd laugh if you knew the whole story, but the short version is it ships with 2 of them...Steamhead said:Agreed. But why the float-type LWCO? The 80 series is tapped for probes.......
On a gravity-return job, we usually return those for credit, and install the primary probe LWCO in tapping F2 (lower try-cock tapping) and the secondary in tapping P (secondary level control tapping). These are all 1" and can be bushed down as needed. F2 is rather close to the sight glass but a McDonnell & Miller PS-800-series LWCO will fit.
I tried to capture just the tapping page but couldn't. The manual is here:
http://www.weil-mclain.com/sites/default/files/field-file/80-manual_1.pdf
And here are some pics showing how they fit:
http://forum.heatinghelp.com/discussion/153445/boiler-replacement-on-larger-webster-type-r-system-finally-ready-to-post
Unfortunately, many people don't blow down float-type LWCOs, so we've gone to probes everywhere we can. The most recent boiler replacement we posted was a dry-fire from a stuck float-type LWCO.All Steamed Up, Inc.
Consulting-1
