2-wire Gravity furnace fires up when wires directly connected, but not with t-stat
sf_mike
Member Posts: 2
- I live in San Francisco and have a 1940's gravity furnace, 2-wire setup.
- Any t-stat I connect doesn't consistently fire up the furnace (most recently got a new Honeywell Round)
- However, when I touch the 2 wires directly together to close the circuit it always fires up.
- Have triple-checked the wiring on the t-stats, in fact the first one we inherited when we moved in and the furnaced fired up just fine, then stopped consistently doing so about a year ago.
- Don't know much about furnaces, is there voltage that comes out of the furnace and perhaps is it not strong enough once I connect a t-stat to cause this problem?
Appreciate any expertise and insights!
Do you have a 120 volt supply to your furnace?
You may not and that's fine.
You may what is called a powerpile system, if so the pilot flame produces enough electrical power to run the gas valve.
That power generated is fairly weak and requires very good electrical connections.
A power pile thermostat is a special animal.
The first one may have lost its ability to close its switch and provide a good connection, which tying the wires together will provide.
Picture of the gas valve would help.-1 -
Glad everyone's happy'd up!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
