Sealing combustion test holes on pvc
Paul_69
Member Posts: 251
in Gas Heating
what are options for properly sealing combustion test holes on high eff.boilers/furnaces after taking tests in the pvc venting. Seems like most boilers have provisions built in but some do not and condensing furnaces almost never do.
Any thoughts about plastic threaded plugs?0
You may need to run a tap in before a plastic plug would thread in.ratio said:Any thoughts about plastic threaded plugs?
I've put a stainless steel hose clamp around the hole. The clamp off a 3" no-hub band works well. Maybe note "test port" with a black sharpie for the next tech.
Brass plug will self tap tight enough to seal good?
Thx0 -
I prefer stainless plugs, I've seen too many brass plugs rot away from the condensate.0
Stainless steel is best!0
Thx Tim. U need to drill and tsp pvc or will the plug thread in itself0
I pre drill the hole and then use the stainless steel bolt to tap the PVC.0
Thx for clearing that up Tim. I think this is the best way. Taking reading of co outside at termination is not as accurate?? What size bolt 1/8?0
I use 1/2" as it is easier to work with. I also use a little RTV sealant on the threads.0
Brass plugs will rot through within 2 years. 3/8 plastic threaded plugs with some pipe dope work.0
