Main steam vent
dc07736
Member Posts: 15
Hi,
I am working on a steam system 100 years old in Kingston NY.
1 pipe system
20 cast iron radiators- present boiler is Burnham natural gas.
Was once coal, then oil now natural gas.
Am presently installing a used Burnham steam boiler 140,000 BTU
No sign of main steam vent, do I need a large vent like this?
Any pipe I cut seams clean, do I need to flush the system?
The valves on the radiators seem to work, is it worth upgrading?
Thank You -Dennis Connors
1 pipe system
Find a plugged/capped tee, cut in a tee, or drill and tap to add a proper main vent somewhere about 12" back from the ends of the horizontal steam mains. No 1-pipe system has ever suffered from being vented properly. Air vents get the steam out of the boiler and into the heat emitters. That makes for efficient operation. Always.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
The steam pipes don't need any flushing BUT any returns that have water in them need to be flushed or replaced. Carefully inspect any returns that have water sitting in them because they are rusting from the inside out.
3PSI gauge1 -
Bob,
Thanks for info,
Burners were completely clogged.
Cleaned the burners, removed jets, they looked clean so we reinstalled.
Original design had no main steam vent,
do you advise one.
Thanks
Dennis Connors
Kingston ny0 -
Is this two pipe steam? Any signs of it being and old style vapor system? Some of those vented into the chimney. Take a look around and post pictures of anything that looks odd.
3PSI gauge0 -
If this really is one pipe steam -- double check that! -- then you do indeed need main vent(s) at the end of any steam mains, more or less as @JohnNY suggested.
However, if it is two pipe steam or particularly a vapour system (a variety of two pipe steam) then you may not need main vents on the steam mains -- or you may. Go to the ends of the steam mains and check to see if there are crossover traps to the dry returns. If there are, and they are working, you do not really even want vents there. However, what you do want is main vents where the dry return(s) end and turn down to become wet. You want those whether there are crossover traps or not.
On the valves -- probably no point in messing with them.Br. Jamie, osb
The only purpose vents would serve on the mains is to quickly chase the air out so the steam can get to the radiators as quickly as possible. The quicker the steam gets to the radiators the quicker the rooms warm. The quicker the rooms warm the quicker the thermostat is satisfied. The quicker the thermostat is satisfied the shorter the boiler cycle. The shorter the boiler cycle the smaller the fuel bill.
Other than that...
Yes. You need them. Big ones. Call @JohnNY. Maybe he'd like a weekend Upstate. Watch the leaves turn...
New England SteamWorks
newenglandsteamworks.com0 -
I like that description RIgwgillplumbingandheating.com
System is 1 pipe
All steam vents are missing from radiators -probably taken for junk value.
Have to buy new ones
Should I use adjustable or plain vents o the radiators?
DC - Kingston NY0 -
If your starting from scratch, guessing what size vents to use on which radiator can get pricey. Adjustable vents let you experiment, DO NOT BUY the Durst brand at Home Depot - they don't adjust anything.
That leaves you to choose between Hoffman 1A's that can be tricky to adjust and a bit pricey or Maid O Mist 5L's which is a kit with one air vent and 5 different size screw on orifices.
https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias=aps&field-keywords=hoffman+1a
https://www.amazon.com/OMIST-0220-5L-Angle-Steam-Valve/dp/B003DV3AGE/ref=sr_1_2?ie=UTF8&qid=1476618544&sr=8-2&keywords=maid+o+mist+5l
3PSI gauge0 -
Tunstall also offers adjustable radiator vents. PM me for details.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
20 radiators and only140,000 BTUH? Sure that's enough?0
The thing about vents is that while they let air out quickly they also let it back in - quickly. The original system didn't let any air back in when it was heating because the fire never went out. This breathing in and out every cycle is an unfortunate consequence of the on/off fire control. Two pipe systems are easy to control not letting the air back in and will run much more quietly and efficiently that way - I have done it for years now.
On the first cycle air does not have to be vented out quickly because you can't heat the pipes up that quickly - there is plenty of time on that cycle with a small vent. After that most of you need fast venting, but only to get the air back out that you let back in. Seems (is) quite a waste of effort.
Someone needs to figure out something for you one pipers. You are buying a vent for every rad anyway. There must be way. Air is the enemy. Need to keep it out.
1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control1 -
Would Hoffman #3's work?0
Very good luck with Swan Vent-Rite #1. Tool free adjustment, scale tracks well, wide range, tough to plug.Dennis0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
